Leaking FEL... but not the quick connector
legbuh
bx2680
Sep 28, 2020
19
mn
Got a newer BX2680 and just noticed a leak from the FEL at one of the connection points.
Before I try to tighten, reseat or whatever (don't want to make a mess) any ideas on what this could be? I think it just started this winter.
The connection is circled in this pic (the connection on the right):
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
Try to tighten the fitting, but make sure you have a backup wrench on the square block holding it or you can very easily crack the tube.
legbuh
bx2680
Sep 28, 2020
19
mn
So I shouldn't try to reseat it? I tried to tighten in gently and it seemed tight.
6,599
You could loosen it first then reseat it, but like whitetiger said put a wrench on the square block and then tighten the nut, it's a flared fitting so it need to be pretty snug.
4,668
JIC 08 - finger tight and mark with a Sharpie. Then tighten 1-1/4 to 1-3/4 flats with a wrench.
legbuh
bx2680
Sep 28, 2020
19
mn
Its darn near impossible to get a wrench in there. I did and I think it moved a little. I just don't like how hard it is to access and I don't want to make it worse. I'm gonna keep an eye on it and my fluid level for now unless anyone has any tricks on how to better access them/tools to use.
5,070
You could remove the outer line first, so you would have better wrench access to that back flare nut.
legbuh
bx2680
Sep 28, 2020
19
mn
Eh.. I'd rather not risk more leaks. I was able to get in from the inside part of the FEL. I think it did move a hair... so far a couple hours later an no leaks. We shall see over the next couple days I guess.
cthomas
LX2610 HSDC
Jan 1, 2017
865
580
La Farge Wi
Also inspect the flare for a microcrack. I am guessing it is just loose as I found a couple loose on my backhoe.
5,070
Flare fitting nuts are loosened, and tightened again every day .....everywhere.
No need to be afraid of loosening, and re-tightening.
