My B3350 is finally "finished" and will be delivered today or tomorrow.
The cylinder head was "rebuilt" including new valve seals to stop oil from getting past the seals/guides, being burnt by the engine, and ending up in the DPF. Do not know what else was done to the cylinder head as the work was done at a Kubota authorized service center.
Additionally, the DPF and reformer were replaced.
Kubota diagnostic software indicates all good and both dealer Sr Tech and Kubota service rep are satisfied that all is well.
Tractor was put on dyno to load to operating temperature so as to force a non-parked regen under load. All went well.
The story is that even a small amount of engine oil past the guides and seals creates an over fueling indication during non-parked (normal) regens resulting in a DPF OT and immediate engine shut down. My dealer has done similar cylinder head work on 3 or 4 other such engines as directed by Kubota. None of these machines has come back with regen problems but the jury is still out.
I was also told, that once engine oil gets into the DPF, the regeneration procedure will not remove it. Accordingly, the DPF was replaced.
FWIW, tractor indicated a bit over 30 PTO HP, but it's a 250 HP dyno so who knows.
I'm cautiously optimistic that all will be well but it will be awhile before I'm confident as I do not put many hours on the 3350.
I'll post back in a few weeks one way or the other.
Edit: Tractor was delivered today, 12 weeks to the day since picked up. Forecast is for rain this evening and the next day or two so won't use it for a few days.
SDT
SDT
