Landscape rake for B7510
zachary.h.miller
2007 B7510HST, LA302 FEL, Woods Brushbull BB48X Rotary Cutter
Feb 12, 2015
Hot Springs, AR
I'm still pretty new at all this, so let me know if I'm approaching this the wrong way:
I've been looking a lot at, and strongly considering purchasing a landscape rake for use around our 10 acres (big yards, some brush and rocks, a 300' gravel driveway, some light leveling and hole-filling). My questions are as follows:
What sizes should I be looking for? Best as I can tell, the problem wouldn't be so much whether the 3ph will pick a heavier rake up, but more having enough tractor weight/power to pull the rake effectively. I know I won't be plowing with it, but I want to be able to use it right. On the other hand, how small is too small? The rakes I'm looking at (ETA brand) range from 191lbs-419lbs, how much weight do I need to be effective? If my wheelbase is 60", would a 60" rake work, and where do I draw the line between manueverability and efficiency?
Sorry for all the questions, but I really trust all the wisdom on this site, so I know I can get some great advice.
Thanks!
-Zach
6,382
For your HP and wheel base I would say a light 72" would work great for you. ;)
6,382
Would you say there are any general rules (i.e. the lighter the better, etc.) regarding rakes?
I personally don't think a rake needs to be heavy to work right.
And you also do not have an L with a lot of lift capability. ;)
Stay with a brand name unit and you should be good.
LeeBo337
Jones, OK
-Zach
I have the same question and need(s) as the original post.
Zach: What did you buy? How did it turn out? Any insight that you’ve gained?
