average_gardener
Kubota L1501,Tiller 48,Finish Mower 48,Disc 48,Blade 48, Bush Hog 48, etc
My Landpride RTA1050 48" tiller that I recently bought is leaking gear oil where the seal to the tine shaft and sprocket share a bearing. I hope this makes sense. It leaks down within a couple of days. It has a cover guard for the chain and sprockets. Even if it leaks down to the bottom of the seal, there is is still a couple of cups of oil for the chain and sprocket to sling around. It may or may not lube the bearing well enough. Anyway, instead of replacing the seal, someone suggested to me to just pump the chamber partially with grease, maybe a tube or 2. Or heck why not more to be sure. What do guys think about this? It sounds like a good idea to me. It would be a lot thicker and should not leak as bad, if at all. Do you have any cons? It would save me from tearing it down. Another option is just to refill it with gear oil before each use. That would be a bummer.
