Land Pride SGC0554 Claw Grapple Grinding Noise??
Ogarret
South Carolina
Hey All,
Just picked up a new B2601 with Land Pride SGC0554 claw grapple a few weeks ago. After it’s initial use the grapple seemed to make a weird grinding noise when clamping brush or logs. Have operated other grapples in past and never experienced this. Does it have to do with lack of grease zerks or just weak steel creaking? Has anyone else experienced this with their LP grapple. Thanks for any input.
Crummy
LX2610
Jul 29, 2021
14
9
Alaska
I have a SGC0554 and I drilled and tapped the hinge point to install grease zerks. Not sure if that's where your noise is coming from but if so it's a easy fix.
Grindstone
B2601, FEL, BH, MMM
Mar 10, 2022
174
109
CT
Did you have to modify anything else or you just were able to drill and insert zerks to get the grease to disburse?
top gnome
Dec 12, 2021
461
219
Fundy shore nova scotia
I know you probably know this but are you holding the button down after the grapple closes. deadheading the hydraulics. that makes a funny noise
4,242
one more thing is check your teeth,, sometimes they get ahhhh bent,,, dont ask
Ogarret
South Carolina
Thank you all for the responses. I used a needle to insert some grease on all the fittings and sprayed some oil lubrication on them as well and noises went away. The fact they don’t have grease zerks is beyond me.
GrappleDave
New Kubota L2501
Mar 19, 2022
37
44
jackson NY
I can tell you from experience that you can not find (at a reasonable price) any small pins or bolts with grease fittings, I have been trying to find a 3/4" x 2" bolt/pin, stud what have you with a grease fitting and I have yet to find any that aren't 8 to 10 bucks a piece. I would love to use them in my builds. It's all about compromise, to keep the cost down and quality up.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
I know this is an old thread, but I've been using my grapple more often and would like to replace the pins with some with zerks on them.
Or drill and tap the hinge parts to take a zerk, but I don't think the steel is thick enough to clear the pin with a zerk threaded in.
Obviously I would have to change 4 of the pins to none cotter pin type. Pins on both ends of hyd cylinders take cotter pins.
Nothing is mentioned in my manual about lubing this unit. There are zero zerks. 6 major pivot points... each end of the hyd cyl and 2 on the claw.
Any suggestions for a good place to buy bolts set up to take a zerk at the end and a lube hole midway down the length?
I can make my own but I will spend more on drill bits, I think.
LandPride SGC0554 grapple.
5,619
Drill and tap the pins.
#7 HSS drill x 2 = $1.60
1!4-20 HSS tap x 2 = $6.50
4,242
I was thinking about drilling the bolts and then cross drilling about half way and tapping for a fitting in the bolt head, I havent looked real close but I think you could do the same thing to the pins though you would have to off set the main hole. But since I dont have ,nor do I know how to run a lathe, I doubt either of those things are going to happen,,,, HINT HINT HINT
5,619
Can you run a drill press? HINT, HINT...
5,773
1st thing I saw was that some lazy SOB needs to snag HIS palm on one of those cotter pins and NOT have a box of bandaids real handy !!!
2nd was a mighty 'cheap' design/build to NOT have greasable pivity things ! Gee, if 'they' cheaped out there , what does that say about the entire unit ?
3rd my '57 Willys pickup had greasable bolts on the spring shackles, can get them for trailers as well !
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
I agree. Hard to believe.
