Land Plane vs Box Blade
BigO 6060
L5030/ L6060/ L6060CAB/ ZD331
Apr 24, 2017
SC
I use the 72” box blade for knocking down heavy soil and rock in smaller areas and out in the woods. I think its capable of pulling/ pushing more weight. I like to keep it on the rear for counter weight, general knock down of piles/ humps and I keep my reciever bolted there to move a trailer if necessary. Even use it to back a log or limbs out of the way when bushogging, etc.
The grade scraper has no equal on finish smoothing and grading. I use the 84” model on my L6060 and love it.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
435
303
Bayview Township
My box blade spends more hours used as ballast/counter weight than for grading. You could probably rig up something to easily hang more weight if needed. Nicer than when I use to have a 8ft blade hanging from the 3pt for a little added mass.
Caseknife
L3130HST
Jun 29, 2026
NE Washington
I have the Land Pride GS1572 grader scraper and maintain a 3/4 mile community lane behind a L3130. Don't use the scarifier blades because it just uproots the base rocks. Haven't used a box blade but my impression the box scraper would require more HP because it carries the material where as the grader scraper allows the excess material to flow over. I have found that if it is real compacted it works better to break up the material by going backwards and letting the weight of the implement work. To do that though requires purchasing another blade to install on the back otherwise you are just using the framework and not a replaceable/reversible blade. We had 170 yards of 3/4 minus delivered last summer and and that gave me something to work with.
ferguson
L3130
Jan 19, 2022
333
138
w.v.
Hi All,
I recently posted asking opinions on land planes and got great responses. I have a gravel road that gets packed down turning the winter freeze/thaw cycles. I need something to dig up the gravel and level some bumps. I was looking at a 4 ft land plane for my 23 hp BX machine. A friend suggested looking at a 4 ft box blade saying it would do the same thing as a land plane but be more versatile for other things. I have no experience with either implement and would appreciate your feedback.
Thanks
Blueridgerunner
I use this homemade land plain
Tim Horton
302
74
Lake Superior
Trivia...
At a time I used a ...cheap China made auto farm store brand 5' box blade to good success for gravel road, farm yard upkeep.. I had a ...homemade bolt on ...shoe... that could be used on the front edge of either ..sideboard.. This and selective use of the ripper shanks, adjustment of the top link and other little adjustments did a good enough job to keep from having to ...invest... or ...invent... another attachment.. Maybe requiring more ...seat time... to do the job, but again cheaper..
Good luck..
miker2702
b7500 and l2501 farmall cub powerking and 8n
Aug 4, 2025
20
10
east tenessee
wonder if you could take a box blade and cut off the back side to land plane level where what you drag flows out instead of piling up inside i can pick up a box blade fairly cheap and modify with a torch....land plane in my area usually around a thousand bucks.
Missouribound
Jun 17, 2014
668
62
Missouri
If you are maintaining an existing road a land plane is easier to operate and will give great results.
But if you need to break up packed down gravel and move it around a box blade is necessary.
Land planes are for the most part surface skimmers. If you keep it maintained it will give great results.
But they lack the digging power (and scarifiers) that a box blade has and have no real ability to move material.
3,126
There are land planes with scarifiers.
Here is one example
