How about a 3 point version? Something like this.....So your using a tractor with a SSQA landplane?
If so, you're not going to get the results that a skid steer would get as the geometry of the loader is completely different.
A 7 ft land plane is probably 2 ft too big for a BX1880.
I'd much rather drag a land plane off the 3pt rather than the FEL, mainly because of visibility.3 point version
Was just a picture to show what style. Think a 6 ft would work though. Missed a used one on FB for a grand. Trying not to buy new. Around $1600 plus for new.A 7 ft land plane is probably 2 ft too big for a BX1880.
Considering the Land Pride 1548. The 4ft model as the largest for the BX2380. Thinking the +400 pounds plus whatever gravel is being dragged uphill will be the limits of the 2380 which has ~25% more hp than the OP's 1880. JMHO, why push your tractor to max limits. Watched an older YT video of a user using the 1548 on his 2380. For whatever reason he was only grading in the downhill direction. Driveway didn't look that steep.A 7 ft land plane is probably 2 ft too big for a BX1880.
The Land Pride 1548 is an appropriate size for your BX2380 and certainly for the OP's BX1880. The Land Pride land planes are very nice. I have the 1560 which I use on my LX4020 and going uphill dragging gravel does use some power. Also if you ever plan on using the rippers you want to keep the size of the land plane reasonable.Considering the Land Pride 1548. The 4ft model as the largest for the BX2380. Thinking the +400 pounds plus whatever gravel is being dragged uphill will be the limits of the 2380 which has ~25% more hp than the OP's 1880. JMHO, why push your tractor to max limits. Watched an older YT video of a user using the 1548 on his 2380. For whatever reason he was only grading in the downhill direction. Driveway didn't look that steep.
Land Pride still shows the GS1548 on their website here:Found some 1548's used in michigan. Land pride doesn't make a new version in 48 inches, according to there web site. Am in no hurry so will keep an eye on CL or FB for used ones. Thanks folks.
Yes, you'll be much happier with a three point land plane.
When I looked earlier on there web site, showed 60 inch and up. Going to keep looking for a used one.Land Pride still shows the GS1548 on their website here:
Land Pride
www.landpride.com
i would do float. be very careful you can rip your fel apart if something gets a little wonky. a tractor fel is nowhere close to a skidsteer for ruggedness. while it can do it you just gotta go very slow and careful.You folks using a land plane (skid steer type), do you put the FEL in float? Am thinking yes but figured I would ask you pros first. Thanks.
You could sell the skidsteer plane for decent money to buy a 3 point one.The adapter would be allot cheaper
Used land planes are a rare find at my Kubota dealer or through private sellers up here. I think demand is relatively high. Lot of gravel driveways up here. Relatively heavy rainfalls(3.5" over couple days) recently. Was a good rain. Zero damage to the driveway. Blue rock gravel "rocks". And the way too dry woods are now ok. Old gravel road would have had cuts and deep ruts down to the rocky layer. Maybe why land planes are popular. Less money and time in the long run to build a proper base and coat with blue rock. Box blades, grader blades, mowers. Wide choice of different brands.Found some 1548's used in michigan. Land pride doesn't make a new version in 48 inches, according to there web site. Am in no hurry so will keep an eye on CL or FB for used ones. Thanks folks.
