LA525 Loader Hose Question
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
268
486
Moseley, VA
Loader is a LA525 and I developed a significant leak on one of the hoses to the main boom cylinder. Looking up the part number on Messicks it appears that there are two potential matches and one is approximately $48 and the other $103 which makes little sense to me. It seems that they both reference some cryptic part number of (E 350 G 06 3) but two different part numbers of 7J999-89060 or 7J999-99062. I can't seem to find anything different other than price. Any of you guys have any insight? I will call a few of the local dealers tomorrow but one is 30 minutes away and there are three others just over an hour away.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
702
316
Herald Calif.
Just remove the hose and take to your local NAPA Auto Parts store or a good hydraulic store close by. These hoses are nothing special . Most likely your Kubota dealer would make it as well.
cliffboyer
L3301 w/LA525 loader, G5200 mower w/RC48 deck, Kawasaki 610 Mule, DR mower
Nov 30, 2017
281
82
Southern IL
It appears to be leaking where attached to the arm. First thing I'd do is check that fittings are tight.
6,992
Its a 3/8" R16 hose with JIC-08 female swivel ends. About $20 in parts plus labor to make. As already mentioned make sure the swivels have not loosened before replacing it.
Outnumbered
Oct 26, 2019
268
486
Moseley, VA
Thanks guys, it was definitely bad and was leaking very badly at the crimp. None of the local dealers had it in stock but as 007K... mentioned one was willing to make the hose for just over $30. less than 10 minutes and a half gallon of UDT2 later back in business. :)
