Is it structurally safe to use a strap through the round tube on the LA525 arms to increase the weight lifting ability of the LA525 loader.
Last time I lifted this same load using straps on the front of the bucket it maxed out the capacity and would only lift 6” off the ground.
I only need to get it 6” off the ground, which was done with the bucket on the LA525, but I would appreciate more margin and stability when lifting this load.
I will be crawling speed wise.
