LA1251 on an M6800
amschind
Kubota M6800/Westendorf TA26, IH 82, NH 648, NH 472
Sep 30, 2024
49
26
A few of you may have seen my efforts to get a Westendorf TA26 onto an M6800. I deeply appreciate all of that help, and am happy to report that it worked great. The loader is a beast and I use it often. I am in the market for an M9000 to pair with the M6800 for heavier tasks, and adding things up, the best cared for tractors mostly have LA1251s already on them. Most come with buckets and attachments, so I'm in the circumstance of 1) just having two sets of attachments (one for the Westendorf QA on the M6800 and one for the Kubota QA on the M9000) 2) finding a diamond in the rough M9000 4x4 ROPS with no loader and adding a TA28 3) buying a Kubota M9000 with an LA1251 and replacing it with a TA28 and selling the 1251 or 4) replacing the TA26 on the Kubota M6800 with a 1251. LA1002s are unobtanium, but 1251s with an M9000 bracket are available.
I recognize that #1 is the most practical and likely what I'll do, but I want to consider all of the options. #2 and #3 are probably the worst, as the tractors on #2 just tend to be gambles (I got lucky once, I don't care to roll the dice again) and the setup to make a Facebook TA28 fit an M9000 is about $7500 all in (Kubota loader PB kit, control block, hoses, used loader, new mount brackets). I can get a used LA1251 today on Facebook for $2500, which would require a further $400 in hoses and control block, and a full Westendorf TA26 set would recoup more of my money than a 1251, which is what lead me to option #4.
All of that for a relatively simple question: will the loader mount bracket for an M9000 also fit an M6800? Is there any other issue that would prevent me from mounting a 1251 on an M6800? That's kind of the core question that determines which path is most cost effective if I don't pick #1.
Thanks!
11,010
The loader mounts look nothing alike, so your chances of if fitting are very unlikely.
amschind
Sep 30, 2024
49
26
Looks aside, the engines are exactly the same, but I know that the M8200/9000 frames are about a half ton heavier. It's hard to guess at because the V3300 is common to the 6800-9000 even if other parts are different.
hedgerow
472
459
Malcolm NE
I have been down this same road so many times its crazy. I try to have every piece of equipment with a loader have the same quick tach but it never works out around here. I had got to the point every loader here had SSQA then I bought a JD 7320 a few years ago with a JD 673 loader that had JD quick tach system that had been used for years on a lot of different loaders models . Tractor came with a bucket and a set of forklift forks I though no sense and changing it to a SSQA so I bought a bale fork for it for loading round bales on trucks. If I were you I would just have two systems and be done with it. Its not that big of a deal to have some extra attachments around. I would just buy the next tractor with a loader on it and it will probably have a bucket on it and if you need some forks just buy some to fit it.
amschind
Sep 30, 2024
49
26
That's almost certainly where I' m going. I also built a hydraulic Tpost driver and folks for the Westendorf QA, and if I went this route they would get sold for a fraction of their value to me along with the TA26. Assuming that I got $2500 for the LA1251, the overall cost for a used but self-refurbished TA28 would be about $5000. I will probably try having two exclusive sets and if it causes me $5k worth of trouble then I'll bite the bullet.
Thanks all!
