L6070: L6832 CCV Kit?
CounterMeasure
Kubota L2501, Z422KW, B2601
Aug 3, 2026
10
Hello all, I am in the process of buying my forth Kubota tractor; a decked out L6070PRMC.
The dealer and I are having quite the ordeal getting it built. A number of options have long lead times that would put part availability to be December or later. I am not willing to wait that long.
One of the options I selected was the defogger kits. While the defogger glass is in-stock at warehouses, the defogger options are listed to require "L6832/CCV kit", and the Kubota told the dealer that L6832 has an ETA of December or January at this point.
What I am trying to decide is if I should go forward with the defogger glass install at time of purchase and self-install L6832 later, or skip the defogger options altogether if the install work related to L6832 is extensive. The issue is that I can find almost no information on what L6832 is or what is in it. Most I can find is "CCV" is misleading based on https://shop.kubotausa.com/oemparts...6838-l6070-l6832?lid=6076df904f231b5030d5bd5a
Anyone have good information on it?
JasonW
857
578
Al
I believe Messicks has a video out on these. Is that apart of the Nordic cold weather packages? Probably not needed in Texas.
I believe CCV is the crank case vent.
CounterMeasure
Aug 3, 2026
10
Everything I read is that "CCV" as in "Crank Case Ventilation" is misleading in this case. If you follow the link I provided above, none of the parts shown are part of a typical cold weather crank case ventilation setup. My dealer has questions out to Kubota to learn more since the70-series is new to them as well, but Kubota is in no hurry to help them. Took Kubota over a week to provide ETAs for dealer-installed options.
Kubota makes a durable tractor, but their documentation and support has always been less than stellar.
CounterMeasure
Aug 3, 2026
10
Just to close up this thread in case anyone else runs into the same confusion I did.
The L6832 option is indeed misnamed as a "CCV Kit".
It is more like a "CCV prerequisite" kit or in layman's terms, "large current draw prerequisite" kit. It consists of upgrading the 60A alternator to a 130A model, larger battery charging cable, new belt, and a few other things. For cold weather models, this option is needed for the electric heater that is installed in the crank case ventilation system to prevent ice build up, or if the defogger glass with electric heat elements is installed.
My plan is to go ahead and have the dealer install the defogger glass as part of putting in all the options fr the delivery next month, and I will install the bigger alternator later on whenever its available.
Do I need defogger glass? No. But I told the dealer I want every option available because I like buttons and switches.
MtnViewRanch
913
378
Lakeside Ca.
So, when you say every option, does that include 3 rear remotes as well as the top & tilt cylinders?
I ask because the Kubota top & tilt set isn't really engineered for Kubota cat 1-2-size tractors and doesn't have any check valves, which are pretty much required with the Kubota rear remote valves.
Just curious. :unsure:
CounterMeasure
Aug 3, 2026
10
I optioned with 3 rears with float detents along with T&T, because that's what I want for my use cases.
BAP
Dec 31, 2012
3,181
1,298
Not sure why you need window defoggers in Texas. Have run cabbed tractors in cold New England weather for 40 years and never had an occasion that I needed defogger glass for a tractor or industrial loader glass.
PaulL
B2601, MX5200.
Jul 17, 2017
2,798
1,791
NZ
Didn't sound like a NEED. Sounded like a WANT. Perhaps even the most powerful word of all - a DESERVE.
CounterMeasure
Aug 3, 2026
10
Thank you for understanding! I am building the tractor I want for my use. But I will also take deserve. :)
I thought my original question was pretty straightforward; not asking if I should get or if I need a specific feature.
winemkr
L2800
Aug 15, 2025
Leelanau, Michigan
I just ordered my new L6070, I told the dealer to max out the tractor with the cold weather options plus Nokian tires. The CCV kit is included in the cold weather package. I got lucky, a guy canceled his order, now his tractor will be mine in a few weeks.
QUOTE Kubota L6070PRMC-CWP • 4cyl Kubota Diesel Engine, Turbo Charged • 60 HP and 53.0 @ PTO • Factory Cab with Heat, A/C, Heated Air Ride Seat, BT Radio, F/R Wipers, F/R Worl Lights • LED Front Head Lights, • 2 rear Remotes • Side and Rear Window Defogger • CCV Heater • High Amp Alt • 3 Range Hydrostatic Drive High, Medium, Low • Cat 1 and 2 3pt Hitch, Lift Capacity 24” behind 3pt 2,310 LBS • Nokian Snow Tires with Rear Tires Loaded • Block Heater • 13.5 Gallon Fuel Tank Kubota LA1056 • L2291 72” Q/A Bucket • 3rd Function • Grill Guard • Lifting Capacity at Pivot Pin 3,029 lbs • Lifting Capacity at Pivot Pin Max Height 2,471 lbs
CounterMeasure
Aug 3, 2026
10
Mine will be ready around late September or October, as the critical cutoff of features was the 3rd remote that has a lead time of September.
I had to drop a few smaller features like the rear camera as the lead times for some features is December at the soonest. I will install those myself when available as they are easy enough. From Kubota on lead times of features:
Special Factory order with all options already installed:
Build Time – 8 Month ETA
ETA if Dealer installs Options:
4-5 Month ETA
L6070PRMC- In stock 3-4 days shipping time
LM1056 – Currently out of stock. Estimated availability is late December. (LA1065 is Currently in stock)
L4606 Rear Defogger kit – In stock 5-7 days shipping time (CCV Heater is needed)
L4607 Side Defogger kit – In stock 5-7 days shipping time (CCV Heater is needed)
L6832 CCV Heater for Defogger kits - Currently out of stock. Estimated availability is late December
L4610 Base Kit and 1st Lever – In stock 5-7 days shipping time
L4611 2nd Position and Lever Kit – In stock 5-7 days shipping time
L4612 3rd Position and Lever Kit – Currently out of stock. Estimated availability is September
L8308 Double Acting Valve - Currently out of stock. Estimated availability is September
L8309 Float Valve - Currently out of stock. Estimated availability is September
L2498 Front View Camera – In stock 5-7 days shipping time
L4601 Rear view Camera – Currently out of stock. Estimated availability is late December
L4602 Camera selector - Currently out of stock. Estimated availability is late December
Air Ride Seat – Currently out of stock. Estimated availability is late August or early September.
L2200 3rd function valve – In stock 5-7 days shipping time
L4605 Rear wiper kit - In stock 5-7 days shipping time
L4632 Rear work light kit - In stock 5-7 days shipping time
L2269 Brush Guard - Currently out of stock. Estimated availability is late October
L8388A Top-N-Tilt kit – In stock 5-7 days shipping time.
3,100
Texas is a large state with a few different eco regions. There are miles of coastal plains that are humid most of the year. There are thick forests, mountains, a few rivers, high plains, man-made lakes, and then there is the desert out West.
I think most people think of tumbleweeds and desert but that isn’t all Texas offers.
Shawn T. W
Dec 9, 2024
807
1,456
SW Missouri Ozarks
De-FOG, is different than De-FROST, while both use A/C dehumidified warm air, they are caused by different things ...
I quite often have a "fog" problem, not so much a "frost" problem in the areas all over the country I drive. Of course in COLD weather I have the heater going inside of my semi-truck if it's parked ..
But I also tend to use my heated mirrors more to clear fog, than frost/ice ...
CounterMeasure
Aug 3, 2026
10
I won't speak for 40 years of New England weather as I have no experience in it, so I wouldn't venture to tell people up there what they need or don't need.
I do have experience in this part of Texas, and we have a lot of mornings were humidity is very high and dew point is not far away. Thus, air conditioning makes the morning work more comfortable, but causes condensation on the windows. The electric de*fog* option, as the previous poster correctly called out, has its uses for condition. And, from my financial standpoint, I see no harm in adding it as the cost for it is less than 2% of the overall tractor cost to include it. The tractor will be paid outright; won't be paying interest on the tractor or the option.
