L48 HST Issues
D100jj4
14
Verona VA
I bought an L48 tractor last year.
I can’t run unit for long periods, once it gets up to operating temp tractor doesn’t have enough power to move. . I have to let it sit and cool off then it will move. So I changed hystat oil and filter, didn’t change anything. Oil doesn’t get hot.
I checked charge pressure and found 100 psi at high idle.
I inspected charge relief valve. I shimmed it up and was able to achieve 220 psi but that’s as high as I could get it to go. Spec is around 370.
I believe I might have an internal leak.
Has anyone ran into this or have any thoughts as to where I should look next.
Thank you!!!
11,197
Have you looked at the Mecanical clutch at all?
Low input power to the HST unit can cause all the issues you are describing.
D100jj4
14
Verona VA
I checked the pedal adjustment.
But haven***8217;t checked the clutch.
How can I check to see if its slipping.
Can I check speed of pto shaft and see if it slows down some after it gets to operating temp?
11,197
Yep that's exactly what you need to do, put a PTO powered implement on it and run the tractor till weak, then run the PTO and see if you have speed and power to it. ;)
