Several years ago the composite plates that connect the coupling shaft to the engine and front hydraulic pump on my L48 failed as sis their replacements. Some kind soul on this board directed me to the factory solution that my local dealer hadn't heard of: a shaft with CV joints on either end to replace the entire assembly. Now THAT shaft has failed after many hours of service.
My local dealer says the part #32771-99702 - "KIT JOINT, F PUMP" is not available and is back ordered until next spring or later. If it was available this small shaft lists for about $725! I found 2 national parts houses that claim to have it in stock, but when pressed don't actually have it.
Meanwhile I've got a tractor sitting in an awkward spot with no way to lift the front bucket. Any suggestions?
Zippy
Zippy
