L4600 Hazard Light
Waushara- Kubota
L4600
Oct 16, 2026
Saxeville, WI
I have an L4600, the top rear fender mounted hazard lights stopped working. When I check with a relay tester to the light socket it shows power and blinks, when I test the relay at the connection under the fender that works. When I put the bulb back in the socket….nothing. The fender hazard lights work, turn signals work etc.
Could it be the switch on the panel that I push to activate the hazard lights?
whitetiger
Nov 20, 2011
3,799
2,203
Kansas City, KS
Your light is not grounding. Loosen the nut under the fender and retighten it a couple of times.
