l4200 REAR PTO seal
Hobo.NC
L4600
Apr 19, 2019
Sanford, NC
I need to replace the rear PTO seal. My question: do you remove the bolts on the rear PTO cover and just pull the shaft out the rear of the tractor. I am doing rear axle seals. I have drained the fluid. It's a 1996 L4200 GST.
11,268
You will remove the bolts and remove the housing and all the parts in green.
7,349
Hey Hobo,
This is pretty far afield for you - are you lost? šŸ˜€
TOH
Hobo.NC
L4600
Apr 19, 2019
Sanford, NC
30 year old botas are in my future. I have a customer that has a fleet of'em I hauled this one in for a front axle seal/bearing job. While here the rear axle seals and PTO seal like to drip on my nice clean floor. Its time to potty train it again.
Sometime back you referenced this site I saved it just incase I needed to ask a question. I have an observation on another issue. I have done 6 are so front bearing/seal jobs I always take the complete steering knuckles off and do a full clean/seal, and all bearings if needed. You know from my pass I don't leave noting unturned.
This is my first final drive gig. The nut that retains the axle from what I have see on the net folks find it lose when they put it back together they install it lose like they found it. They reuse use the old nut. Its a $75.00 nut I tried as best I could to salvage the old nut, Bota did not have to completely thread the inside of the nut. When you try and tap the crimp up from its lock position you damage the threads inside the nut I did not like that so I used a dremel to cut the crimp section out. As carful as I was the nut came off hard, It did not do much damage to the axle threads. I called my local dealer and ordered two nuts. I asked how many nuts have they sold she tells me 2 and that was in 2022.
I am doing the other side I plan to cut the crip section out and not try and punch the crip section up/out. I know folks are not going to be happy I am buying new nuts but nuts are cheaper than a new axle. I will let Y'all know how the other side goes. The videos I have watched they use the old nut and install it back lose like they found it. I read it has a torque spec 181 lb ft, I wounder how it got lose to begin with.
7,349
Glad to hear business is good and you are still kicking it. Your wisdom and experience will be a big asset to this community šŸ‘
Hobo.NC
L4600
Apr 19, 2019
Sanford, NC
About 20 years ago I did some extensive work to the transmission on a L3600 GTS. When I put it all back together the PTO did not work. I split it again the overrunning clutch had fell off. Somehow I missed seeing it laying in the bottom of the case I just wanted to make sure it would not fall off by removing the PTO shaft.
On the rear axle nut when I do the other side I am going to get the torch out and heat the divot/punch mark and see if I can save the nut that way.
Hobo.NC
L4600
Apr 19, 2019
Sanford, NC
The shaft came out no problem the shaft was about 16 to 18" long. What got the PTO seal was fishing line. The axle nuts both were loose I heated the dimple/crimp in an attempt to pry it up without damage it was a no go. I cut the crimp/dimple out of both with a Dremel tool. Because they were loose when you go back with the original nut and tighten it to torque specs you will have a new place on the nut to lock it down. I chose to use new nuts. If you beat/pry on the dimple to raise it up you will damage the threads I would not go there.
