L4150 4wd Front tires have play between rim and housing, looking for help.
Bucket55
L4150, L4400 + many attachments
Aug 13, 2023
K0M 1C0, Ontario, Canada
All lug bolts tight, but slight play when I push and pull on both front wheels, housing behind rim does not seem to move but I can feel movement between rim and housing, whats up?
6,926
That model has a unique front end, and it has a nut for hub lash like on a trailer axle or a truck axle.
I would get the WSM to find out how to set it.
rbargeron
Jul 6, 2015
1,171
238
western ma
If the hubs turn smoothly without leaking or making noise, you can probably live with minor bearing lash. If you decide to go in, here's a WSM page for the L5450 - same constuction as the l4150. May need to improvise pullers for the cover and seal. The hub nut is lightly tightened to eliminate bearing play and staked in place. Check that the hub still turns smoothly. Take care, Dick B.
Bucket55
Aug 13, 2023
Thanks for the info, not leaking and does turn smoothly, I was worried the wheels would break off, I will see what is going on asap.
rbargeron
Jul 6, 2015
1,171
238
western ma
Front end loaders on these models are rated up to 2500 lb so everything is pretty rugged . The bearings might get worn - but something actually breaking off is unheard of in my experience.
