Hi folks,
I am new to the forum but I am looking forward to learning as much as I can about Kabota tractors.
I have a 4060HSTC. I backed it out of the shed, set the engine to idle, engaged the PTO to bush hog, raised the engine speed to 2000RPM and started mowing as usual. After just a minute or two the tractor decided to drop engine RPM down to idle speed all by itself, then after about 5 seconds increased back to 2000.
-I was in very short grass but raised the bush hog up just in case but it repeated the problem again.
-I turned off the PTO switch, which disengaged the bush hog but the problem persisted.
-I pulled the tractor back into the shed and turned it off so I could have a look.
-I rechecked all fluid levels, drive belt, etc. Also looked at the air filter (great condition, very clean).
-Tried to re-start the tractor and it turns over great but will not start.
-I checked all the fuses, removed the output line from the fuel pump and turned on the ignition, fuel flowed great.
-Checked the water separator and all is good there.
-The tank is full of fuel.
-Tractor has about 450 hrs on it.
Has anyone ever experienced this before or is the time to call the dealer and have them come get it?
Any suggestions would be most welcome, thanks!
