L3940/L2194 Snowblower Detachment
ranger118
L3940 & L2194 snowblower
Sep 6, 2014
McCall, ID
I've got my snowblower detached but I can't get the front driveline off of the tractor. The driveline shield is supposed to be spring loaded so you can pull it back but mine won't budge. Any ideas?
9,159
Try spraying any part of the coupling with PB Blaster to break loose any rust. And some times a tap on the side of the collar will help it move.
9,159
Stick some grease in the fitting before you put it on for the winter, will make it come off in the spring so much easier!
Oh a greetings from Way North of you!
McCall was my first choice of where I wanted to live in ID, Just wasn't any work there at the time. ;)
