L3901 Rear Weight How much?
CapnDean
L6060,ZD1211
Feb 22, 2018
183
Gulfport, MS USA
I am looking for recommendations for weighting the rear end. I have the L3901DT with R4 industrial tires. Rear tires are filled to 75% capacity - I also added 1.5" spacers increasing the width if the machine 3".
With the LA525 FEL and my 6' box blade on the back, I am still light in the rear.
A full scoop of dirt or gravel and I will lose traction. Want to add some weight, but don't want to over do it either. I'm guessing the bb weighs in at 250# - it's not a wimpy one.
How much weight do others use on the 3 point as ballast?tick of ra
I have a 6' stick of railroad track that I plan to cut and weld to the BB.
11,231
You want about 1200 lbs to 1500 lbs off the three point. ;)
Yooper
3901 LA525
May 31, 2015
1,749
927
NE Wisconsin
I have 1000 lbs on the rear wheels and all I can say is the L3901 loves rear weight. You will notice the improvement immediately.
Ortimber
98
Oregon
Like others have said, a 1000lbs +. My box blade weighs almost 600 lbs and that's not enough to take advantage of the available loader capacity.
TiftTyson
2018 L2501 HST, LA 525 Loader, Landpride Rotary Cutter, Box Blades;Bush Hog Til
Mar 24, 2018
19
ATHENS, GA
My L2501 handles a LA525 loader of topsoil well. In NE GA our topsoil has a fair amount of clay mixed with it. It is not full of organic matter. The L2501 should be similar in weight and dustribution to your L3901. I usually have A BB that weighs 360 lb along with a quick hitch that weighs 70 lbs on the back. My R4 tires are loaded as well. No loss or traction or feeling tippy. I have moved almost 3 tandom truckloads of dirt in the past couple of weeks. The quick hitch does move the BB back 4.5 inches.
I could always use my tiller as a counter ballast if needed. It weighs 693lbs.
I have not moved gravel. So I can not speak to that.
Grizzy3901
L3901hst, la525, 72" landpride finish mower
Jan 1, 2017
67
Bealeton va
I found some chunks of lead that I add when needed. 4 block plus a 60 inch areator was all my 3pt wanted had to take the 5th block off
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
To your question not sure what weight you need but I have the bigger cousin L4600 and I built a carryall to use for ballast and among other things.
The carryall I suspect weighs in around 200#'s, I filled (5) 5 gallon buckets with scrap blocks and cement weighing in at 80#'s each and then added 150#'s of gym weights under carryall for a estimated total weight of 750#'s. The buckets I can take off when not needed and they store easily with lids on each one.
This seems to work well for my setup.
