L3901 - overheating after extended, heavy duty brush hogging
mattwithcats
784
77
Grease the zerk fittings
Sharpen the blades, I keep two sets around to make this easy…
If your running Kubota HH164-32430 oil filter, and mowing open areas,
use a Wix 51773. Extra quart and a half of oil…
If your may snag it on something, use Wix 51515…
marktm
BX2660 - 2012 model Land Pride RCR1248 shredder
Aug 30, 2025
My BX always seems to run toward the top of the temp gauge. Probably not surprising here in South Texas during the summer. However, yesterday the gauge went to the hot mark so I stopped and noticed the overflow tank was bubbling (not boiling) from the radiator cap. I let it cool for 30 minutes and checked the fluid level - seemed full, but the overflow tank was empty. Upon restarting, everything seemed OK, but I did not stress it much after that. I'd been cutting dense 2 ft grass for over an hour (Bahia?) at top speed. I do keep the radiator area clean with a strong ego blower. Hope I've done no damage.
3,678
The overflow tank seems to be working properly then.
As the machine heats up…the expanding coolant eventually over-pressures the radiator-cap relief and the coolant escapes the radiator tank.…into the overflow tank (also called a reservoir.)
Before the use of overflow-tanks…that coolant would be lost onto the ground, never to be recovered. Radiator tanks were oversized to allow for large air-pockets to exist above the coolant in that radiator tank when it was cool.
Newer designs utilized an overflow tank (reservoir) to capture that hot, excess coolant. When the machine cooled back down…the coolant contracts…creating a suction which sucks the coolant from the overflow tank back into the radiator tank…. and so on, and so on. (The advantage being that the radiator tank was always completely full during operation regardless of temperature. This also avoids atmosphere from entering the radiator tank….reducing oxidation of coolant and corrosion of radiator.)
A small amount of coolant should always remain in the overflow tank. If your radiator cools down and sucks the overflow tank completely dry…then you might add a pint or so of coolant to the overflow tank…. Then observe it for several operationa-periods… until it stabilizes with a couple inches of coolant always remaining in the overflow tank.
Hope this helps.
