L3901 loader frame
pete75
L3901
Jan 15, 2018
middlesex ny 14507
When I back drag bucket with down force the left side of frame makes a sound like something breaking. Has I look it over the frame upright is bent where if pivots. Des anybody else have this problem. Tractor as 133 hrs on it.
6,596
What is the Loader #?
3,722
really need to see a pic....any chance you have KTAC insurance on it?
mikester
M59 TLB
Oct 21, 2017
3,601
2,084
www.divergentstuff.ca
Check all the mounting bolts on the frame and loader. My NH had a bolt shear off right where the loader frame mounted onto the tractor chassis. I heard a loud pop when it went as I was carrying a load in the bucket. PITA to fix.
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
29
Ventura Ca
So tell me how did you go about repairing the broken loader frame bolt ? I’ve had 2 shear off over the last 8 years one I was able to get the bolt out . Then drilled out the hole tapped out the hole installed helicoil . The second one I can get the broken bolt out and it won’t drill out . Thanks for any info you may have ....Dan
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
437
41
Red Springs, NC
Maybe able to weld a nut to the broken bolt. I bought some rods from Exergon will have to check the numbers they are called extraction rods. I have had great luck with them most recent was removed a exhaust bolt on my 6.0 gas broke off flush in a aluminum head
