L3901 Hydro Clutch disc
Tractor Tech
Southern California
I use a rototiller on my tractor quite a bit. At 4300 hours, I lost the clutch. When I split the tractor, I expected to see disc parts or a burned clutch. I found the disc was turning on the hub. The hub isn't rivited to the hub.
My question, is there any reason that I can't put a rivited disc in the tractor?
Old disc pictured.
5,241
It sounds like you are contemplating using a clutch disk that is NOT factory?
I do not have any experience with this, but I do recall that any attempt to “resurface” a pressure plate will ultimaly end in failure, so exptrapolating this idea further, I “highly doubt” that a “substitute disk" is a good idea…..
But I was wrong “once” before….;);)
I'm sure someone that actually "knows something" will be along shortly to confirm/deny my suspicions though….
Good luck sir…. (y) (y)
7,166
That clutch disc is made by Exedy. :unsure:
Tractor Tech
Southern California
Guys, yes, I am thinking of using an aftermarket disc that has a rivited center. The OEM disc doesn't have rivjts and failed at the hub. Is there a reason that Kubota may not use a rivited disc on a hydro transmission? Or is this just a different way of assembling a disc?
10,911
EDITED:
I would not go with a riveted clutch
That clutch is designed differently that a riveted clutch and you could very easily do damage to the HST.
Tractor Tech
Southern California
Yes, folks, it is identical to the disc I pucked up today.
I went with the Kubota disc after all. I was concerned about the hydro transmission and this disc.
By the way, no pilot bearing on this setup, so I'm guessing it 'floats' a little for the hydro.
Old disc lasted 4300 hours, so I fuess not bad for the heavy use. I'm just not used to a clutch center failure with no visible signs.
Thank you everyone for your opinions!
10,911
Money well spent! ;)
