L3901 Hydraulic top link
6,889
What size would you recommend?
Cylinder diameter, rod diameter and pressure?
Pressure does not matter.
The important parameters are retracted length, bore, stroke, and to a lesser degree rod diameter. I recommend getting one with a DPOCV.
The one on my L3901 is 2" bore, 20" retracted, 10" stroke, and 1.25" rod. Works well for all of my stuff.
MtnViewRanch
901
360
Lakeside Ca.
2" cylinder with a 1 1/4" dia rod is all you need.
I have found that a working length of 20"-29" is ideal.
Look at the following link, get the asked for dimension and find a cat 1 toplink that is close to the asked for dimension at the mid stroke position.
This will provide you with an equal amount of adjustment for YOUR implements.
