L3901 and 6’ shredder?
walkerbrt
Houston, Texas
New to the group and soon to be new Kubota owner this Spring. I’ve never owned a tractor before and will be using it for mostly shredding (@50 acres) hunting areas. I am looking at the L3901 for smaller size to maneuver around oak trees, but really want a 6’ shredder to keep up my fencelines and bigger hunting pastures. Will L3901 struggle with 6’ shredder?
Ideas.....thoughts?
walkerbrt
SDT
multiple and various
Apr 15, 2018
3,256
1,042
SE, IN
Ideas.....thoughts?
walkerbrt
Yes.
I would not recommend a 6' cutter for a 3901 except in IDEAL conditions.
Then it would need to be a light weight one and you will need front weights if not on nearly level ground.
SDT
edritchey
A bunch of cute little Kubotas
Jul 19, 2014
1,107
806
Wellsville, PA
I guess it will depend on how big in diameter the stuff your cutting is.
I used a Land Pride 6' light/medium cutter on my old L3901 and it did just fine cutting tall thick grass and weeds an inch or less in diameter.
Mine was a HST model and I never noticed it lugging pulling that cutter around.
CapnDean
L6060,ZD1211
Feb 22, 2018
184
Gulfport, MS USA
I'd stick with the 5' bush hog. I have the L3901 and a 5' land pride. I also have a 6' bush hog that I pull with my 45HP Farmtrac.
Well...as it goes I once hung the 6' Bush hog on the kubota. It was nice to be cutting wider than the tractor - But it's just too much for it when truly bush hogging. I do MOW with a 6' finish mower behind my L3901 it does good like that.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to OTT Walkerbrt.
As you can see, that you have come to the right place to get answers.
