L3800 Shuttle shift operation
10,854
EDIT: Gave bad information, read on.
Kingcreek
Grand L3010 GST 4wd, LA481FEL, various attachments and accessories
Aug 3, 2011
457
NW Illinois
My manual recommends stopping movement before shifting F-R or R-F. I just use the brakes and only rarely do I use the clutch.
Bluegill
Jan 11, 2012
1,559
Success Missouri
You have to come to a complete stop and use the clutch. It's not a shuttle shift, but just a forward/reverse.
10,854
So is it just the hydraulic shuttle shift that you can change on the fly?
I can do it with mine, but I have a GST and they work differently than a DT.
TripleR
Sep 16, 2011
1,911
SE Missouri
I'm not familiar with the L3800, but we have synchronized shuttle, non synchronized shuttle and hydraulic shuttle.
non synchronized shuttle: stop movement before reverse/forward, need to use foot clutch.
synchronized shuttle: no need to stop movement before reverse/forward, just do it at relatively slow speed, need to use foot clutch.
hydraulic shuttle: no need to stop movement before reverse/forward, just do it at relatively slow speed and no need to use foot clutch.
Bluegill
Jan 11, 2012
1,559
Success Missouri
The L3800DT has a non synchronized trans. Have to stop and clutch it. Old school gear trans with a separate leaver for forward/reverse.
Our old 3750DT has a Hydraulic Shuttle, no need to stop or clutch it.
The only basic L with a synchronized shuttle is the L4600DT, but still have to clutch it I believe.
10,854
Thanks TripleR, and Bluegill for the clarity and explanation.
GST's do work rather odd, they have a mechanical synchronized shuttle, but are run by a hydraulic clutch.
Dhunt4work
L3800DT
Dec 24, 2014
35
Roanoke, Indiana
I guess I am still confused on the shuttle shift. I am told that it is supposed to save time when using a loader since you only have to shift the lever forward and reverse? So what I am hearing is that you have to clutch each time? What about the main shifter is it in neutral and your just using the shuttle shifter to go forward and reverse?
Anyways I called Kubota service and asked them...they have to call me back....really? The tech looked it up in the manual, but it is not really clear....that's what I thought too.
Thanks
TripleR
Sep 16, 2011
1,911
SE Missouri
You don't do anything to the main gear shift, it will be in the same gear going forward or backward.
Bluegill
Jan 11, 2012
1,559
Success Missouri
TripleR has it right.
Don't you have an owner's manual?
The lever you are calling "shuttle shift" on the left side of the seat, is just the shifting leaver for Forward Reverse & High Low range. You have to clutch it to change gears.
9,117
Question? On the newer shuttle shifts on the forward and reverse lever, does it also have hi/low range on the same lever :confused:
On my dads L2250 he has the non synchronized shuttle shift. It has two levers, one on each side of the steering column. Left lever is forward/reverse. Right lever is gears 1-4 and shifts in a side ways H pattern. Hi/low range lever is to the left of the seat. You can get reverse in all speeds except 4 hi. And have to use the clutch for direction and gears
TripleR
Sep 16, 2011
1,911
SE Missouri
I don't think so on Kubota models, the HI/LO range lever on our M8540 is to the right of the seat in front of the gear shift lever.
Catchad81
Notasulga, AL
The shuttle shift at the left of the seat typically has to be clutched. The shifter by the steering wheel that can go from forward to reverse on the fly is often called a power reserved or hydraulic shuttle shifter.
MattyNH
Kubota L3800DT, R4 tires, Bradco Forks, Third function valve
Oct 15, 2014
41
Lake Winnipesaukee New Hampshire
Thanks
I own a 2013 Kubota L3800DT..It is a gear drive tractor. It does not have shuttle shift!!! You need to clutch the tractor to change gears or go in reverse.. The lever beside the tractor seat ( the reverse,high,low) where is saves time by not moving the main shifter on the tranny itself..so if your main tranny shifter is in 3rd gear..using the lever by your seat..your in 3rd gear reverse, third gear low or third gear high..Keep in mind you still need to use the clutch to go in reverse ,high or low gear..If the main shifter is in neutral..The whole tractor is in neutral
