L3710hst hydraulic pump seal failure
dag1450
Sep 5, 2014
chalfont
I bought this tractor with 3000 hrs a couple months ago and recently changed the engine oil. I did notice at that time the oil was high on the dip stick but just thought PO messed up on filling. After my oil change i noticed the oil starting to rise on the stick every week. So i called the dealer and they said the seal between the pump and crank case is bad and said u really should replace the whole pump. Ouch $1000 for the pump, the seal is $6. Has any one done just the seal and had luck with it lasting and for how long? Was it hard to get the old seal out? This is a spare part time tractor and will not see many hours per yr. Any info and help would b very much appreciated! Dave
kubotasam
Apr 26, 2010
1,206
129
Alfred Maine
I have never tried on a Kubota. I have done just the seal on a couple of old Farmall tractors my dad owns. They have lasted quite well. He however does not put lots of hours on his tractors.
olthumpa
L275
May 25, 2011
1,501
Maine
For $6 I know what I would try first. :)
Agree
I changed the seal on mine. It lasted about a year than it let go again and I changed the pump.:( Some have had the seal go shortly and others have had much better luck. IMHO it's a crapshoot.
What ever you decide, good luck.:)
dag1450
Sep 5, 2014
chalfont
Yea im thinking just like CJN8. I could do on every year and still be ahead. I will order two. I like to order more than i need just in case i mess one up on the install or in this case have it for next time.lol Thanks guys i will let u know how it goes....maybe in a couple weeks. Dave
Tooljunkie
May 13, 2014
4,150
My forklift did the same thing. The pump is like two chambers, one low pressure and one high,if seal is leaking, most likely its wear, a redi-sleeve and a new seal should cure it. If it popped out, the high pressure side is faliling and pressurizing the case. Then a pump is the cure. Or a rebuild.
dag1450
Sep 5, 2014
chalfont
Thanks Tooljunkie. Yesterday i pulled the pump off. It only took about a half hour, the other half was dealing with the hard and stiff return hose. Seal does not have any obvious failures but still could b worn. This is held in by a internal snap ring. took the ring out now i just need to get the seal out. Dave
