thanks, i had seen mention of how to remove the gst valve but it wasnt clear it needed to come out before hand. also it didnt look fun, saw a warning about not droping some pin. here is what i found in the wsm on the gst valve, not much just enough to pucker me up.
and removing the clutch housing
this was all i could find in the parts catalog and it doesnt seam to show what the wsm was warning about.
it mentions locating the different shift pins in neutral or high/lo prior to reassembly but i am not seeing what it needs to be. i figure i can get it apart but what concerns me is getting it back together so it works. do i need to look up something else in the catolog or wsm besides the gst valve ot mid-case/clutch housing
i is this shuttle check pin something i need to take extra precautions to not drop or just be watching before i turn it over or set it down?
when i get it apart should i expect it to be obvious how the propeler shaft will come out and the access to replacing those seals or is there some other section i need to read?
thank you again
fingers crossed
kenny
thank you again
fingers crossed
kenny
