L3600 Leaking PTO
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,883
2,399
WestTn/NoMs
My nephew has an L3600 leaking out of the PTO shaft. The repair looks straightforward except for one item - there is a splined coupling between the output shaft and the PTO drive shaft. I assume the coupling is free to stay on either shaft or, most likely in my experience, fall off in the gearcase. Assuming it falls down in the gearcase, will I/he be able to fish it out through the PTO hole?
11,083
Yes you can get to it.
The norm is the splined coupling with stay in the case on the front shaft.
