L355SS Charging problem
Sandor
L355SS
Oct 9, 2015
Mannington
Hello, I'm new to the forum, hope you can help. I have an old (1970's ?) L355SS which has been running great. Last summer I have replaced the alternator and adjusted the voltage regulator so that at the battery I got 13.8 charging voltage. Just recently the battery wouldn't charge. I checked the voltage and only got 12.6 v at the battery. The voltage regulator wouldn't adjust, so I replaced it. Even with the new regulator I still get only 12.6 v at the battery, which doesn't keep the battery up. Any suggestions?
Thanks
Sandor
11,496
Pull the battery and have it load tested, a bad battery will pull the whole system down.
While you did change the alternator out a while ago it could be bad again, do a full test on it.
I'll PM you a link for a download of the WSM look on pages 28 and 29 for the complete test section.
Sandor
L355SS
Oct 9, 2015
Mannington
Wolfman, it is the alternator. The battery is so-so but should be okay until winter. Is there an on-line source for alternators ? Can these be rebuilt?
Sandor
rbargeron
Jul 6, 2015
1,185
262
western ma
Several places offer the 15471-64010 alternator delivered under $90 - just google or eBay it and pick one. I used to get alts & starters from Pat's small engine - but the server is off line.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Williamstown Ontario Canada
If you have a local small business alternator and starter repair shop, they can often fix these often for less than a new one.
Dave M7040
