L355SS 4WD leaking oil
05harley
L355SS
Jul 20, 2014
jamesville, nc usa
I have replaced both front spindle oil seals on my L355SS but they continue to leak oil pretty bad---to the point I have to top off the lube in the front axle housing before every use----I followed the steps in my repair manual but still did not get it right----any words of wisdom from anyone who has done this successfully would be a great help to me---tx in advance---Randy
rbargeron
Jul 6, 2015
1,151
220
western ma
Are you quite sure its the spindle seals that are leaking? (there are 3 more seals) As a check, try taking off the wheel, cleaning the area with solvent, and winding several turns of cotton string around the spindle/hub next to the seal. Run it a while and see if there's an effect. If not maybe there's a hairline crack in the cover ?
