I have recently purchased a L355SS. It has 600 hours, 4X4, L1720 loader with its own hydraulics reservoir and pump (mounted at the bottom of the front below the radiator). I replaced the Hyd fluid and filter for the loader. I just replaced about 2 weeks ago the transmission/hyd fluid for the tractors the old walkinky, no, not good (8.8 Gal). I believe that the 3pt is powered by the tractors trans/hyd fluid, not the loaders pump and reservoir (correct me if I am wrong). About a month ago I was able to lift a bush hog with the 3pt, but it did have some initial hesitation and drove it back to the house about a mile. I had replaced the fluid before I went and picked up the bush hog. I just purchased a box blade, backed the tractor up, lowered the 3pt to line it up. It was a little low so I went to raise it slightly and that's when it wouldn't go up at all. I pulled it forward, gave it more gas, nothing, wouldn't raise an inch (nothing attached). I got off and was able to lift the 3pt arms very easily by hand. When I changed out my fluid, there were 2 fill pugs and either 5-6 drain plugs. I believe that I replaced all fluids but I am a newbie so that I could have missed something. The 3pt does have a lift and a draft lever. I am attaching a picture of a plug that I am not sure of its purpose. I doesn't look like the plugs for the transmission. I has an O-ring on the plug itself. The second picture is looking down where the plug goes and the last is a knob taht is dirrectly below the seat that I do not know it's use (any info there appreciated as well. Sorry for the long post but I know the more info the better. Thanks for the help!!!
