L35 loader issue
waltweems
L5030, L35
Nov 10, 2015
10
cooksville
When I place the edge of the loader bucket , model TL720, down on the ground and back up to level the turf, the bucket just rolls over rather then remaining in place.
Am I missing some setting or adjustment?
Walt Weems
12251hd
M6800, L35, RTV
Nov 23, 2018
55
Woodbridge, VA
Check the linkage that keeps the bucket on the same plane when you raise or lower it. It runs along the upper loader arm. Good luck.
7,240
Walt Weems
One other possible issue is you could have a blow seal internally that is letting it bypass fluid. ;)
waltweems
L5030, L35
Nov 10, 2015
10
cooksville
Thanks for the thoughts on the problem. Since there are 2 cylinders controlling the bucket, would a bad seal on one cylinder cause the problem?
Walt Weems
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,251
1,032
Williamstown Ontario Canada
Weems
Walt
The few people I gave this cylinder testing procedure to told me it was easy to follow and identified if there was a problem.
Does your loader valve have two levers or a joystick?
Dave
mikester
M59 TLB
Oct 21, 2017
3,681
2,192
www.divergentstuff.ca
Did you apply down pressure? The little bit of oil in the lines will act as an accumulator if you simply drop the boom down to ground level without down pressure and the boom will float a little.
