Hello all,
My apologies if this is covered before but I've tried searching the site. My old tractor has hydraulic fluid slowly getting into my oil (definitely not antifreeze or diesel). The oil level has always slowly dropped and I'd have to add a bit from time to time. It now goes up at the same rate (and my hydraulics pump makes a bit of noise when raising the bucket). Plus a sample from the slow rear main seal leak does show clearish fluid separating from the oil, matching the Kubota hydraulic fluid.
Does anyone know which seals I need on the pump? I will be replacing the seeping o-rings at the inlet and output lines while I have it off of course. I'm on a chromebook so apologies as I can't seem to post the exploded parts view! It's a Canadian L345DT and I can see the exploded diagrams here: https://kubota.ca/parts-finder. I'm fairly mechanicaly inclined and it's easy to get to so I'd like to do it myself. But any help on which seals I'd need would be very much appreciated!
Best,
Scott
Best,
Scott
