J Jeremy126 New member Equipment L345 Aug 14, 2019 14 0 0 Woodbury TN Aug 18, 2019 #1 What is the stock wheel and tire size for the L345. Cause I’m not sure if my is stock.
motionclone Well-known member Lifetime Member Equipment L345DT with Lp mower, forks and grapple thumb, Bobcat 337 Midi Ex May 4, 2018 1,398 992 113 Maine Aug 18, 2019 #2 Heres what Tractordata says for tire size: http://www.tractordata.com/farm-tractors/001/2/8/1288-kubota-l345-dimensions.html I have L345DT and I have 18s on the front but my WSM lists that size as a possibility not sure about other sizes for your machine.
J Jeremy126 New member Equipment L345 Aug 14, 2019 14 0 0 Woodbury TN Aug 18, 2019 #3 Mine has 14.9-24 on rear and thought it is wrong
Henro Well-known member Equipment B2910, BX2200, KX41-2V mini Ex. May 24, 2019 5,178 2,386 113 North of Pittsburgh PA Aug 21, 2019 #4 Jeremy126 said: Mine has 14.9-24 on rear and thought it is wrong Click to expand... Does it matter much, if you tractor is not 4WD?
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,766 5,155 113 Sandpoint, ID Aug 22, 2019 #5 The 14.9-24 has the same RC as the other tires so your fine as long as your running 8-18's on the front.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 28,766 5,155 113 Sandpoint, ID Aug 22, 2019 #6 Henro said: Does it matter much, if you tractor is not 4WD? Click to expand... No it doesn't matter at all, well besides changing travel speeds, you're not going to hurt anything.
