L3430 gaining camber?
Bluegill
Jan 11, 2012
1,559
Success Missouri
I do use the loader (a lot) with no weight on the back end. Having said that it is usually either firewood, or snow, maybe a couple of hundred pounds. I did move a pile of gravel with it about 2 years ago, but the change in camber appears pretty recent. Maybe things just caught up to me. I am going to visit with the dealer this morning to arrange a pick up. Is their any point in having them pull both sides apart to make sure everything is good? It will probably cost me $100 each way to have them pick it up and then deliver it back, so if the other side is going to cause issues in a year or so, why not do both sides now? I appreciate everybody's help, and will post the findings. Go orange, or go home. You guys must love Halloween.
That will do it!
If you're not goin to have weight on the 3 pt hitch, then take the loader off. If you need to use the loader put at least 500 lbs on the 3 pt, 800-1000 if any heavy loader work is goin to be done...
Yes, the dealer needs to check both sides.
