L3350 white smoke
Garrettl1515
B1750 B2150 L3350DT L345DT B7100HST B7100 L2201 B6200
Feb 19, 2024
51
23
Bakersfield CA
Just got an l3350, oil looks over full but does not look like coolant or smell like diesel, radiator empty and has a little smoke after startup. First startup the tractor fired right up sounds and runs good but lots of white smoke. Going to
Dive in it. Most likely a head gasket? Any thoughts
11,468
Most likely cracked head, a lot more common than head gasket failure.
If it's been run (which you say you have) there is also a very high chance that bearings will be damaged too.
Water / coolant in the oil does a lot of bad thing in a hurry.
Now for some possibly really bad news.
That DPF system is very likely loaded with junk and possibly damaged.
If you get the head or head gasket fixed, Do a forced regen and hope for the best.
Wish you the best!
Garrettl1515
Feb 19, 2024
51
23
Bakersfield CA
Wish you the best!
Thanks for the insight, I’ll let you know what I find when I dig into it
