I thought I would share a issue I have been fighting for the past couple of weeks.
It all started as a surging idle. From there my tractor started to die for no reason. Then came the codes PO0089, PO0087, PO2293. All are fuel issues.
I filled the tank with Off Road fuel in June. I have not used it as much thru the hot summer months in Mississippi, as I have a bad poison oak allergy so bush hogging causes lots of problems. I found my first issue in the filter in the water separator was covered with what appeared to be an alga. I replaced both filters and it helped for about a month. This weekend the problem presented itself again.
Today I drained the fuel and cleaned the filter in the water separator again. It was once again covered with alga. Replaced the fuel and once again it is running great . I will add algaecide to the tank tomorrow.
We have always ran off road fuel in dozers and track hoes with no issues. Not sure if I got bad fuel or what.
Anyone seen these issues if so am I on the right track to correct them?
