Fel was up and 3 point was up when arc occurred immediately shutting engine off at 2000rpm in netural.
-Tried to start, only got single grind so I clamped clutch turned manualy only getting 1/4in
Checked slow fuses to mini fuses. None blown. (Did replace ignition since I had one on shelf)
Checked fuel fuel with key engaged gets by shut off fine. Solenoid functions correctly.
Checked starter replaced ground bushings and Solenoid tests good now.
No visible blockage of flywheel.
Towed to a shady rolled freely(clutch still clamped.
Bleed some hydrollic fluid at filter/fel connection/3 point cylndrrs before removing hydrolic pump(bench tested and good)
Removed glow plugs and tried to manually turn stil 1/4 in forward and backwards no fluid escape.
Drained oil to check for expensive glitter. None in pan, oil filter paper, or under valve cover.
I'm out of ideas. Know it not a safety or pto switch it tries to crank. Don't kn
