L3240 80 error
Stils
L3240
Aug 14, 2019
Waynesville Ohio
Started after I ran over some brush, I can see a broken black wire not sure where I goes? It is a single black wire on left hand side near step. all sensor wires look good.
5,143
Range gear shift sensor failure, you sure it's not a black with yellow stripe?
200mph
Mar 3, 2017
1,228
59
PA
Trouble item:
Range gear shift sensor failed
Possible Causes:
Sensor output terminal is out of adjustment • Sensor output wire terminal broken or short-circuited • Input line broken • Sensor damaged
Solution and Reference Page:
Terminal motion is possible –
Check the sensor connector –
Check the sensor voltage by Test mode (Mode A) 9-S22
Check the sensor wire connector (voltage) or check sensor resistance 9-S48
Replace the sensor 9-S48
You might want to purchase the WSM.
Hope this helps.
