I have an 4WD gear driven L3200. It has recently just started shutting off, but not losing power(the dash lights would remain on). At first it would do it every now and then. Now I can’t even put it into gear without it shutting off. It will crank and idle fine in neutral(will literally run all day if I’d let it). But as soon as I go to shift it into gear, it shuts off, if I throw it into neutral quick enough, it’ll stay on and idle. Is there a gear shift switch or anything? The seat switch seams to have the plastic lever taken off, so Id say that’s already been bypassed.
