L3200 air filter
blank102
L3200
Feb 2, 2015
44
Mexifornia
Today I replaced the air filter. The new filter has an outer as well as inner filter.
When I took off the old filter there was only the outer filter.
Anyone know why there would be no inner? Could this be a running change that Kubota made?
JasonW
394
197
Al
My 2014 L3800 only had the outer filter from the factory, I installed the inner filter when it was new.
Tooljunkie
May 13, 2014
4,150
The cleaner the better when it comes to incoming air in a diesel. Generally two outer filters to one inner replacement. Doesent hurt to replace both though.
blank102
L3200
Feb 2, 2015
44
Mexifornia
Thanks to all!
I had no idea that the inner filter was an option. Considering how dusty it is around here it's probably a good idea to use it.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Just be happy your tractor comes with the radial seal filters at all. My L3000 had the old type and I had to change the entire filter system on mine.
The Grand L's come with both filters from the factory. I guess Kubota can't afford to install both on the base model machines.
