L3200 Adjustable Seat “Spring” Pressure
Stitchit1
183
Cheboygan, Mi
I have a question for yas,…. I have an L3200. The seat no longer seems to have much support when I hit bumps. I have it adjusted all the way in, to the setting of most resistance possible. Do the springs fail over time? Or is it just the way it is? (Loose weight?) lol
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
Yes.
It could be worse.... you could have Oliver's tractor and seat.
3,637
Perhaps you’ve adjusted it “all the way”…. in the Wrong Direction..? Try the mid-point.
old and tired
L2800 HST; 2005; R4
As far as I can tell, the "suspension" seat did not change when the L2800 was changed to the L3200. The springs in mine, did NOT fail but the posts that they were attached to both broke. I replaced the welded bars with a bolt that supported both springs.
But before digging into the springs, the seats were/are prone to getting stuck in the down position. I have a very old video (below) that you'll need to click on to view at my old youtube location (I don't know how to make it viewable via the link).
Basically, if you have a good pry bar, you can stick in from the rear of the tractor and work it up and it will stick it back down (which happens a few dozen times until you work it free). Get a can of penetrating oil and go to town spraying it. Mine did not move at all when I first started working on it. It was stuck in the down position.
I did mine in my shop, but you can do it all on the tractor.... Removing the seat and then the suspension section is pretty easy. 4 bolts if I remember correctly.
You can play the low quality, 2009 video, by clicking "HERE"
Stitchit1
183
Cheboygan, Mi
Thanks so much for posting your words of advice and the link to your video! I think I’m following you on it all but will need to wait until I get back to the tractor to confirm. Thanks again!
2,321
The springs can wear out if under tension 100% of the time. That is a possibility but with a low probability. But they are about $30 each (if I looked at the right ones).
old and tired
L2800 HST; 2005; R4
....but will need to wait until I get back to the tractor to confirm. Thanks again!
So if the seat is NOT stuck in the down position, and you can lift it up my hand or by prying it up (with ease). Springs not giving resistance.... This would indicate either the springs broke (unlikely) or what the springs are attached to broke.
Since my spring suspension broke the welded stubs off... it's possible yours might have broken, too. Unlikely but possible. Mine broke most likely cause my seat was locked down good and tight and it took lots of prying to get it to work. Which weaken my studs.
Since I worked so much on mine to free it up (and you did not do that) this is why, I'm guessing yours is just stuck down. Good luck and let us know how it turns out!!
old and tired
L2800 HST; 2005; R4
It's raised up as much as it can be. The suspension seat does seem to be loose at the beginning but that might be normal... I'll look at mine next week.
I would say that your "UP" travel is fine that is the max that it can go up. What happens when you push down? (put weight on the seat). You should be able to travel downward 1.5" (guessing, never measured it) Try backing off the spring to where the down travel bottoms out...
Look at my first video, when I use my hand to push the seat to bottom out... can you do that?
2,321
@old and tired
The video you referred to in post #4 is not able to be seen. It says the “owner” (which I assume is you) disabled playback.
old and tired
L2800 HST; 2005; R4
@old and tired
I no longer have access to that account; the email and password are gone!!
I edited both posts to change the links from the old youtube to be in-bedded into just clicking: "HERE"
old and tired
L2800 HST; 2005; R4
Not to beat a dead horse... but I am!
Your suspension seat is NOT stuck down. The question now is do you have any down travel with the seat. Can you bounce up and down that 1.5-ish inches of travel? Springs are for the up travel which in your video looks good to me. Just check to make sure you can travel downward.
If it doesn't go down, you might have a rock or something else to prevent giving you a softer ride...
