L3130DT won't start - Shuttle Neutral
nfc911
Charles Town
Parked the tractor the other night and now won't start. Intellipanel shows "Shuttle Neutral" and the Neutral light is not coming on. Checked the shuttle switch and it shows 0 Ohms across the pins per the WSM. Pulled and checked continuity across all of the fuses as well. Any other suggestions as to what to test/check?
lugbolt
ZG127S-54
Oct 15, 2015
5,493
2,198
Mid, South, USA
If the shuttle switch shows zero ohm in the neutral position, you have either a wiring problem or connector issue. If everything was working the day before, it might be wise to look for rodent damage to the wiring.
nfc911
Charles Town
Took the 'dash' apart to get to the wiring into the Intellipanel, unplugged some wires, checked continuity from where the shuttle switch connector is up to the panel connector and looked good. Blew dirt out of every crevices and out of the connectors for good measure. Plugged everything back up and working fine now. Must have been something loose or just unplugging/replugging something allowed it to reset. Hopefully one time deal.
