L3130 hst problems
Zreeves
Pickton, tx
I've got a Kubota l3130 hst that just all of a sudden quit moving forward and reverse. All hyd. Functions work properly and strong. If I rev it up and try to go forward it will slightly jump and the pump starts screaming but will not move. Any ideas?
7,408
Could be forward of the HST and it's got a blown clutch.
Could be the HST has issues and needs repaired or replaced.
Could be rearward of the HST and it has a differential issue.
If your a good mechanic then it's something to get into, if your not, send it to a dealer as it requires testing that the normal mechanic can't do.
I'll send you a download link for the WSM it might give you some hint as what to look at.
5,335
2,009
Probably clutch. I've done several of them last year. Splines in the disc get torn out easier than I like to see. New disc is a little different part number so I want to say that they're stronger-but I don't know that because I have no way to test them.
rbargeron
Jul 6, 2015
1,175
242
western ma
........ If I rev it up and try to go forward it will slightly jump and the pump starts screaming but will not move........
How many hours on the machine? Had since new? Any symptoms in the weeks or months before it stopped moving? In normal use do you use the foot clutch pedal often or rarely (using the HST instead)? If the screaming noise starts and stops with the clutch pedal is it the same in L, M,and H?
It sounds like the clutch disk center has broken out. The HST unit is probably ok. If the clutch isn't driving, the HST's charge pump doesn't turn so there's no drive in either direction. The screaming noise is likely the broken clutch center parts rubbing instead of driving.
Zreeves
Pickton, tx
Ok that would be great also anybody know how I can check the pump pressures i.e. Where to tap into
Zreeves
Pickton, tx
300hrs yes owned since new I crawled on it later and it will now go forward but no reverse also use clutch very seldom
Lennyzx11
L3301
Dec 18, 2015
Bennington Vermont
Didn't get knocked out of gear half way on the low medium high shifter did it. (Don't ask how I know that one)
rbargeron
Jul 6, 2015
1,175
242
western ma
...... I crawled on it later and it will now go forward but no reverse.............
From the symptoms the cause is hard to pinpoint. If it wouldn't move forward or back, the clutch could be a possible cause. But if it later changed and moved forward slowly, eventually moving forward ok but still with no reverse, that points more toward HST linkage. It has several rods and pivots where something could be loose, bent, broken, blocked etc. The WSM has info on checking, adjusting, etc. There's a related thread on loss of HST reverse here.
rbargeron
Jul 6, 2015
1,175
242
western ma
...... anybody know how I can check the pump pressures i.e. Where to tap into
There are ports and procedures for checking pressures set out in the WSM. The threaded ports have British straight pipe threads - charge pump circuits run approx 400-500 psi - main drive circuits are ten times higher - approx 5500 psi. Need the right fittings and gauges - and an abundance of caution.
