L305DT idle
Sean2202
L305DT
May 27, 2019
36
CT
Greetings, glad to have found this site. I have a 1982 L305DT that I have had for a few years. I was curious if anyone knew what the correct factory idle is supposed to be. Mine idles at about 1200 RPM. My tractor hours read 5523.
Thanks
Sean
5,328
Thanks
Sean
It's high, should be 800 to 850. ;)
Sean2202
L305DT
May 27, 2019
36
CT
Thanks for the info and replies. I always thought it seemed a bit on the high side. Glad I asked. Yes I was going by the engine tach. I will confirm with a electronic photo tach.
Sean
4,470
Turn it down as North Idaho Wolfman suggested. Just a tad above not running...and you'll be fine! There is no need for it to idle higher.
