L3010 Start Problem
fishpredator07
L3010 HST
Sep 23, 2010
Colorado
Long story short, I can jump the starter and start the tractor. What I can't do is isolate where the fault is yet. Think I have a problem with the black wire with white stripe from the back of the ignition switch to the starter.
I can get continuity from the connector attached to the starter relay down to the starter. I can't get continuity from the connector behind the dash connected to the ignition switch to the the connector at the starter relay or the starter.
Questions:
Obviously, what lies between?
Anyone have a readable wiring diagram? Not the one from the parts manual. I have that, and its just not suitably detailed of the areas I'm concerned about.
How many relays between ignition and starter?
Thanks,
J
fishpredator07
L3010 HST
Sep 23, 2010
Colorado
Thanks Mingy, it helped although I think at this point I'm over my head electronically. I still think its a simple problem, but isolating is a pain. I've called in an "expert", let you know later this week how it goes.
Mingy
L3010 backhoe FEL, B2300, M9000
Jul 27, 2010
Ontario
Keep us up to date - I find vehicle schematics to be really bizarre. They only make sense once you've figured out whats wrong!
fishpredator07
L3010 HST
Sep 23, 2010
Colorado
Wiring fault in the harness behind the panel under the seat. Couldn't see it from under or behind the tractor. Once the panel was off, I could see the damage to the wire. Was no bargain getting the handle off the 3-point drop adjust to get the panel off. Thank goodness that's over.
Thanks for the hand, Mingy.
Mingy
Jul 27, 2010
Ontario
Sounds like a PITA, but it must be nice to have a working tractor!
Do you fix it, or did you send it to the shop?
