I recently repacked the 4 loader cylinders and replaced a few lines, Hyd. fluid, and strainer. After getting everything back together the 3 point hitch won't lift unless I move the loader controls in conjunction with the 3ph controls. I pulled the cover off of the 3ph and replaced the seals just in case and still the same problem. Any suggestions? Thanks all in advance!!
