L2950DT (523 hours) hauling wood up steep grade, made it to the woodshed, stopped tractor and white smoke poured out of exhaust while it lost rpm. Turned key switch off, checked oil, let it cool and tried to restart with key switch. Starter engaged but engine sounded seized with loud metallic like noise.
"Diesel challenged" but didn't just fall off turnip truck. Should I remove injectors and try to manually turn crank? Remove oil and filter and check for metal?
Thanks guys!!
Thanks guys!!
