L2900GST Right Hand Tie Rod Needed
Rich Hays
L2900GST Model 2408
Apr 14, 2026
MO
Hello.
I would like to purchase an aftermarket or compatible right hand tie rod for my L2900GST. OEM is like $600 and I need to find a cheaper solution. All suggestions welcome.
Thank you.
10,671
Rich Hays
L2900GST Model 2408
Apr 14, 2026
MO
Thanks, guys.
The rod part is what bent. So, I think I need an entire rod assembly. See pic.
I believe the OEM part number is HTA01-13700, but this rod looks different and it costs nearly $600.
Certainly there's a less expensive solution.
6,961
Thanks, guys.
You bent it. Bend it back
Rich Hays
L2900GST Model 2408
Apr 14, 2026
MO
HTA01-13700 is just about 18 3/4 inches from the center of one end of the tie rod to the other. Does anyone have any thoughts on using any tie rod that has similar dimensions?
Vlach7
L47 305DT JD500C
Dec 16, 2021
450
322
Frazier Park Ca
Find a heavier duty aftermarket set up, cut out the bent parts and weld it back together for a stronger tractor
10,671
It's not really the length issue as much as the joint size issue.
7,517
It's a tractor. You're not traveling at high speeds. Simply remove the bent rod, bit it in a vise and straighten it. You don't even need heat, just patience.
