L2900 stalls after 4-5 minutes
billwross
L2900, front loader, backhoe, scraper, box scraper, post hole digger, brush hog,
Jun 22, 2014
Grapeview, WA
L2900 stalls after 4-5 minutes (Solved)
My L2900 has been a very reliable tractor for over 8 years. It has about 1200 hours on it and has never given me any trouble. The other day I was grading the driveway and after about 5 minutes it lost power and even after unloading it (putting it in neutral) and giving it full throttle, it slowly lost RPM and died. After letting it sit for a while, it started and ran fine with good power, for about 5 minutes! Then, same problem. I changed the air and fuel filters to no effect. The fuel tank is 3/4 full. Yes, I did look in the tank and verified there is indeed fuel.:) The fuel is fresh, clean and free of water. I disconnected the fuel line at the fuel pump inlet and drained some fuel to check for tank, line and filter clogging issues and it and drained a gallon of fuel in less than two minutes so I’m assuming no problems there as this engine sips about a gallon of fuel an hour working. I reconnected the input line to the fuel pump and disconnected the output line to check fuel flow through the pump. Fuel trickled out but much slower than from the filter output. Cold cranking the engine didn’t seem to increase the flow. The pump diaphragm doesn’t seem to be leaking as it produces a vacuum when the plunger is pushed. It just doesn’t seem to be pumping fuel. Is this normal? I put in a shunt and bypassed the fuel pump and the engine started and ran fine at about 1800 RPM for about 8 minutes. I was thinking Yea, I’ve found the problem but then the engine slowly lost RPM and died again!
I verified that the fuel cap isn't causing a vacuum lock. The shut-off solenoid is working correctly. The shut-off knob is in and the linkage is adjusted correctly and moves freely. I checked the oil level and it was in the lower quadrant of the dip stick. I changed the oil and filter and verified it is not overfull. The oil is in the lower quarter of the dip stick range. The old oil looked and smelled normal. The engine doesn’t seem to use any oil as I never have to add oil between oil changes.
Bleeding the fuel system has been no problem. Sometimes it starts right up and sometimes it sputters a bit and then starts running fine. I haven’t had to loosen the injector lines to bleed them but I have loosened them to check for correct operation. They seem to be working correctly. The bleed valve is closed. One curious thing, the bleed valve was fully open when this problem started and I think it has been open for years as I’ve never touched it. After closing it, there was no change in symptoms but now on opening it while the engine is running it causes the engine to stop.
The engine will idle for quite a while before dying but at higher RPM it will quit after about 4-5 minutes. It certainly acts like it is being starved of fuel but I can’t find the problem. Any help would be greatly appreciated.
OK folks, confession time. DON'T TOP OFF YOUR DIESEL TANK FROM A RED CAN MARKED 'TRACTOR DIESEL' WITHOUT VERIFYING IT IS INDEED DIESEL FUEL! I drained some of the fuel from the tank this afternoon and burned it and it flamed up much more rapidly than some known diesel fuel did. I realized there must have been some gasoline in the can I had recently emptied into the tank so I could refill it on a fuel run. Don't ask me how there came to be gasoline in a red can marked tractor diesel because I don't know. I certainly couldn't be dumb enough to do such a thing! The good news; the tractor now runs great again on its preferred fuel.
OutdoorsmanL3250
North Georgia, US
I am no mechanic whatsoever but i bought my 90' L3250 a year ago, drove and ran it fine before purchase for 30 min or so. Brought it home used it for an hour and turned it off, eat lunch came back and it wouldnt even fire. Had fuel at the injector pump with great pressure. Let it cool to below operating temp and it would run great all day long and would never stall like yours does but if i ever killed it it wouldnt crank back till it cooled. 900$ later i found out by mechanic my injection pump was shot. Apparently the tolerances are so tight in those pumps once they wear they become very finicky. New injection pump later it starts like brand new!! I must also add im at 1450 hrs now. Might be worth having it checked out?
" A gun is like a woman son it's all how you hold her"
TOA #118
billwross
Jun 22, 2014
Grapeview, WA
Hi OutdoorsmanL3250, That was a tough one. I sure hope that doesn't apply to me. On my engine, there isn't 'an injection pump' but actually three small individual single piston injection pumps each activated by a different lobe on the pump cam shaft. It is interesting though that the problem seems to occur about the time the engine comes up to temp. I can't recall if that is always the case or not. I need to explore that one a bit more. Thanks for the tip!
OutdoorsmanL3250
North Georgia, US
Ah, see told i was no mechanic! But hey man, like you i just could NOT for the life of me figure why it wouldnt start when hot?! Especially when i turned it over and had fuel pressure at the pump? It was crazy but hey, now it does start and run better than it did before. Plus, with north Ga not being big farm savvy, our off road diesel tends to sit and get dirty at stations so i now run pump diesel with an additive to protect my pump and injectors from debris in case the filter fails. Its not bad cost wise for assuming i only use my tractor for bush hogging and food plot work certain times of the year
TOA #118
